TwinTurbo.NET: Nissan 300ZX forum - Like a skeleton... .... Nice. Unfortunately,
Subject Like a skeleton... .... Nice. Unfortunately,
Posted by CoHPhasor on March 01, 2011 at 6:55 PM
  This message has been viewed 162 times.
In Reply To Possible manifold exhaust leak (Passenger Side) posted by blackomega on March 01, 2011 at 03:19 PM
Message no, it isn't easy to get to the manifold bolts.
As you've been under there, you already know it's tight down there with the DP and turbo in the way.
The manifold has a heat shield held on by 3 bolts running along its center.
Under that, the manifold has 2 bolts/port, 1 top, 1 bottom.
I'd check the TP/DP and DP/turbo connections.
if you're lucky, it's just a gasket, or a bolt has loosened.
I pulled my motor to get to my manifold.
(Thankfully it was fine)
